Configures the circuit ID sub-option that identifies the specified VLANs to use the default value.
| vlan_name | Names a VLAN to be configured to use the default value. |
| all | Specifies that all VLANs are to be configured to use the default value. |
N/A.
None.
The following example configures VLAN "blue" to use the default VLAN information for the circuit ID sub-option:
unconfigure bootprelay dhcp-agent information circuit-id vlan-information blue
This command was first available in ExtremeXOS 12.4.
